http://dx.doi.org/10.1016/j.powtec.2015.08.031 The Bond number is a dimensionless quantity representing the ratio of adhesive forces to gravitational forces. It is primarily used to characterize whether particle flowability remains consistent after particle coarsening. For more information on the Bond number, please refer to the following literature.
For the bond number you have the equation there (ratio of adhesive forces to gravitational forces) so I expect the question is how to calculate the adhesive forces?
This depends on the physics model used, if using the EEPA model for example the bond number is calculated for you in the EEPA Parameter editor, using the cohesive force from the EEPA equation. Regards
Stephen
Hello,Stephen, My question has been answered. Thank you very much for your reply.😀
