Can EDEM2026 be coupled with Starccm+? What models within Starccm+ does it support? If so, are there any tutorial files available?
We don't currently have a Star-EDEM 1-way tutorial but there is this EDEM tutorial using field data:
The source of the field can be any program, so using Star just have to be able to export a CGNS file of the resolved field. Regards
Stephen
Hi Jin,
2-way coupling isn't avalable yet, but its work in progress. You can export a flow field from Star and import to EDEM for 1-way (field data) coupling.
Regards
thank you !Does it mean that only one-way coupling can be performed now? Is there a tutorial for the specific operation of one-way coupling?
