Hello everyone,
I'm simulating heat transfer in a vibrated bed
In my simulation, the geometry will play a role of a heatsource with constant heatflux
However, the current built-in HeatConduction model in EDEM only supports setting constant temperature for geometry
I have tried to look for a solution through API and found a Plug-in code for geometry as a heatsource (HeatConductionForGeometry_29July2014),
but it was built for old versions, and seems not compatible with the current EDEM versions anymore
Meanwhile, the new supplied HeatConduction code (HeatConduction_CM_v3_3_0) seems to only represent heat exhange between particles (not geometry)
Thefore, I kindly ask for your suggestions
