I mainly engage in structural analysis and multi-body dynamics analysis. As an engineer who frequently uses Altair simulation software, the transition from old interface to new interface has shown me a revolutionary change in CAE software. However, there are some small features that I think may require better development ideas;
You can treat some useless suggestions as nonsense
Suggestion 1: Altair needs to unify all software default operation gestures, such as EDEM, simsolid, which are different from Hyperworks' operation gestures and need to be adjusted separately. In addition, Simlab's selection method is very different from Hyperworks, where the left mouse button can be clicked or unselected. I think these small details can be unified and belong to one company's software;
Suggestion 2: It seems that all software that requires Python API can learn the Python demo function of Inspire2026 and integrate it directly into the software, making it convenient for people who need secondary development software to get started and learn;
Suggestion 3: For Inspire: Can the development team add gear, rope, gear, belt, and track tool kits in the future, similar to Motionview's mechanical tool kit; I hardly use motion view now, the function of inject motion is really useful. It would be even better if a simple hydraulic and electronic control module for Twin activation could be added later;
Suggestion 4: For motionview, I feel that I can learn from Inspire. Some functions of Inspire's Motion have been done perfectly. For example, the output of forces and moments on many hinges needs to be created one by one, which is relatively inefficient. In addition, it is very convenient to debug the model in Inspire, because real-time charts can be produced during calculation, and the calculation process can know whether the parameter settings are correct, but ms is not so convenient; In addition, in MS's mechanical tools, the bearing pair does not support rigid body groups;
Suggestion 5: I also use Simlab. I have observed that Simlab has started supporting star ccm+, but it seems that it does not yet support the generation of polyhedral meshes with star ccm+. Hypermesh CFD also has this problem. Currently, Siemens has acquired Altair, so Hypermesh CFD can fully integrate star ccm+. I have tried the UI of star ccm+, but I think it is outdated and not as user-friendly as the UI of Hypermesh CFD. If star ccm+is integrated, combined with the advantages of Acusole, I think CFD can completely achieve the first place. However, currently I only see some trends in Simlab;
Suggestion 6: When will EDEM replace the UI? I can't stand this old UI anymore, it doesn't look like a product from 2025 at all. What is the development team doing? Do you want to patch tattered clothes? The best solution now is to switch to a similar style of hyperworks, which can fully utilize the hypermesh CFD interface UI. EDEM currently only has one advantage: it occupies the market early, but post-processing is very difficult to use, and the software style is completely detached from the market. If don't make any changes, it will eventually be taken over by Ansys' Rocky; The UI in Simlab is completely better than the UI of independent software now. It's time to make changes;Another issue is that the unit of EDEM is essentially meters. Even if switched to millimeters, when using millimeters in Motionview, the coupling results of EDEM and Motionview will encounter problems when displayed simultaneously in Hyperview
Suggestion 7: Can hypermesh contact pairs add a grouping function? For example, I have 50 contact pairs, ten of which belong to part 1 and part 2, and the remaining 40 belong to part 3 and part 4. So, I created two contact pair collectors to distinguish them, which is very useful for model checking. Why not do such a good function?
There should still be some, but I can't remember for a moment. Forget it, it's useless to say more;
I hope someone can help me forward it to the development team, as not every suggestion may be appropriate
