Can I add custom attributes to the DPM model in Fluent when performing coupled calculation with Edem? This custom attribute will modify the specific heat capacity of the particles. Will the edem side receive this change in specific heat capacity?
You can add custom properties to coupling code: https://help.altair.com/edem/topics/coupling_interface_programming_guide/registering_a_new_custom_particle_property_t.htm
Regards
Stephen
