I'm currently working on doing Thermal loss analysis. The part I'm working with is a half-bridge setup in EconoDUAL packaging. I was able to successfully add a new device and input all the parameters from the datasheet. However, I noticed some other models have it defined that it's a half-bridge setup under one physical thermal package. I've only been able to make this new MOSFET model as a discrete type. I can't seem to find any setting that would allow me to change the package type for my model. Here is the model I've made (top), versus when I select a Cree WAS300M12BM2 (bottom), it automatically changes the model to a half-bridge setup in the same case package.
Thanks for the help!
-Collin
