Using MMO, we are unable to obtain a unified response; instead, we are getting different responses for each load.
In MMO, you will get responses for each model depending on loading.
But there will be one optimized result which will be satisfying all constraints and achieving the objective.
Thanks
Rajashri
Not sure this helps but there are mnay reproducible examples of MMO using Altair SLC and Pyhton.
Python offers robust libraries for multi-model optimization, which typically involves hyperparameter tuning across multiple machine learning models or multi-objective optimization scenarios. Pymoo stands out for handling constrained single- and multi-objective problems with algorithms like NSGA-II, while Optuna excels in hyperparameter optimization for frameworks such as PyTorch, TensorFlow, and LightGBM
https://www.perplexity.ai/search/python-multi-model-optimizatio-NYhYlSp0TBO0JH9YqqRUQw
