The loads are correct, The analysis on Hyperview shows accurate results. but when i go to hyperlife to see the fatigue effects, it doesn't show any results. i've tried: changing the folder paths; creating a global output request on hypermesh to give outputs on strain and stress; putting the scale number on hyperlife to 1500 to see if the software just wasn't bothering with calculating with such low stresses. But nothing worked. I don't know what else I can do, everything seems right, but hyperlife just isn't showing any results.
