Altair slc attempts to fix the autoexec utf-8 error;
Too long to post in listserv, see github
github
https://github.com/rogerjdeangelis/utl-altair-slc-attempts-to-fix-the-autoexec-utf-8-error
PROBLEM
FIX THIS ERROR
NOTE: AUTOEXEC processing beginning; file is C:\wpsoto\autoexec.sas
NOTE: AUTOEXEC source line
1 +;;;;
ERROR: Expected a statement keyword : found "?"
Note '' is hex 'EFBBBF'x
UNFORTUNATELY REMOVING 'Ï»¿', 'EFBBBF'X, Does not fix the problem.
EVEN IF YOU REMOVE 'Ï»¿', 'EFBBBF'X, IT WILL COME BACK
C:\wpsoto\autoexecbom.sas does not have the utf-8 codes.
NOTE: AUTOEXEC processing beginning; file is C:\wpsoto\autoexecbom.sas
1 + %let init= %str(
I don't believe users can solve this isuue. I think it is a problem
witht the slc windows interface.
CONTENTS
1 Display the hidden utf_8 codes in your file
2.Remove the utf-8 codes
3 utf-8 gone error persists
Show that the ERROR is still resent
