I want to copy the data from the panel section in the hypergraph.
but I am unable to copy.
I need max Y values of all the curves.
Hello
Currently this is not possible directly in the tool.
But attached is a template you can use.
Hello jason,
The template gives the same info as the summary option. when we use the export curve option.
I needed the information in table format, as available in the panel section.
Thanks.
