Hi.
I'm making the the certification on CFD Analysis with AcuSolve and SimLab. I'm in Ex.6 but I can't do it properly because I have a problem. In the exercise i have to fill the correct mechanical properties as you can see in image below:
The problem is that my box isn't like that, but is like the following one:
How can I add some mechanical properties and other properties to develop a complete "material card"?
Thank You.
Carlo
