I want to know is there any way to set zero frequency in CADFEKO .
Hi @MohsinJamil_pakistan,
The frequency cannot be set to 0 Hz in Feko because the frequency-domain solvers require a non-zero frequency. They work in time-harmonic (AC) domain. If you want to analyze a solenoid with DC excitation, you can try Altair Flux, which is designed for magnetostatic and low-frequency problems.
Shannon Mistry
Okay got it. Thanks
