Hi experts,
I am simulating a case involving a variable-density fluid propagating in a water tank, and I need to set an outlet at the end of the tank. I tried using a pressure outlet boundary condition (considering hydrostatic pressure), but the results were not very good. Now I want to use a zero-gradient boundary condition instead. I’d like to know how to set this up in Acusolve. Is it done through the element boundary condition settings? If so, how exactly can I configure it? I couldn’t find the relevant instructions in the manual.
Thanks a lot
