Altair slc enhanced autoexec file and ultraedit insert text;
Too long to post here, see github
github
https://github.com/rogerjdeangelis/utl-altair-slc-enhanced-autoexec-file-and-ultraedit-insert-text
CONTENTS
1 ENHANCED AUTOEXEC (file in this repo)
Added pesistent work library, so tables can persist between ultraedit program submissions.
Added enhanced options that no longer requires &_init_
Added handy macro variables
Whats happening
1 The autoexec is run everytime you submit your code in ultraedit
Normally this deletes the work directory,
2 The enhanced autoexec assigns am additional persistent 'work' library
libname workx wpd "d:/wpswrkx"
This library and all its contents will be available next time submit your code.
3 If you want to clear the contents of 'd:/wpswrk' just run this
proc datasets lib=workx kill;
run;quit;
4 all the handy macro variables are assigned.
2 KEY MAPPING TO INSERT TEXT IN ULTRAEDIT (unfortunately, the SLC does not support sqlite passthru? )
Mapped the following code to keys alt + f4
options set=RHOME "D:\d451";
proc r;
export data=class r=class;
submit;
library(sqldf)
options(sqldf.dll = "d:/dll/sqlean.dll")
table=sqldf('
select
from
class')
print(table);
endsubmit;
import data=table r=table;
run;
quit;
