i am doing analysisin optistruct
project detail as per following.
load body (load caring vehicles).
payload 37ton apx.
traget: i want to test strength for floor members . not only floor even all side walls of vehicles. can sastain the load.
problem: master --dummy weight in 3d mesh 37 ton. 2.) slave: load body mesh part. but master weight run out of load body .connect not work properly betwen body and dummny weight.weight goes out of side walls .please help. i dont want to apply pressure or force because at a time it work either on floor or side wall of load body. i want dummy weight will work at a time all sides (floor side and front and rear wall)
file attached for ref.
With regards
priyanka
