HPC Optistruct job failed due to Max wall time given less.
can i restart from the failed job? its almost 98% completed and failed due to max wall clock time reached.
Thanks in Advance.
If you have RESTARTW in your original run , then you can restart it from the time it failed.
Attaching the document for this.
Thanks
Hello, Which scheduler are you using ? Can you increase the walltime ?
