My current requirement is to analyze the thermal deformation and stress of an entire rubber material structure when its temperature decreases from the initial 100℃ to 50℃. However, I found that the resulting contour plot from the analysis shows zero values, which suggests that the coefficient of thermal expansion is not functioning, or perhaps I have entered the expansion coefficient in the wrong location. I checked the help documentation, but I'm still unsure: for the hyperelastic material (MATHE card), is the thermal expansion coefficient indeed input at the TEXP parameter, or should it be set in another location?
Thanks!
