Good evening,
My assignment requires me to import data into AI studio and it's unable to read it. This is my process of importing the data:
Open AI Studio and click Blank Process
- Under the Repository window, click import data and select the file you wish to use.
- Once the data is loaded, under the Operators tab, find 'Read CSV'.
- Drag the 'Read CSV' to the Process window and in the parameters tab, click the 'import configuration wizard' and select the file.
- Click run and then I would get this error:
