i am trying to install Feko2025 on windows 11. However there is an issue that causes the installation process to stop.
The InstallAnywhere proceeds to 100% then it stops and closes. Instead of opening the splash screen as described in the installation guide, nothing happens.
I am admin on my machine, and executed the file also as administrator. I have also double checked the permissions But still no success.
I have also tried the silent mode installation but the bevahiour is the same. As soon as InstallAnywhere is finished. The window just closes and nothing happens.
I have also checked the installer sha256 just in case the downloaded installer is corrupted (it is not).
Is there anyone with similar issues? If yes how can this be fixed?
Thanks in advance.
