Hello!
I am using 4330 steel and would like to simulate the casting process. However, the material file for 4330 is not available in Inspire Cast. Is this file available? Where might I find such a file?
Thanks!
If the required material card is not available, you can obtain its properties from public resource. Inspire Cast allows you to modify and add properties to create custom materials as needed for accurate simulation. If you can obtain the properties of 4330 Steel you can modify one of the closest steel material in the library and create your custom material. Easier solution in case if the properties are inaccessible, try to use closest steel material available in the library and review the results if they are matching.
Regards
