How can I extract the output data (stress) at each integration point in CSV format (Excel table) from the .h3d calculation result file?
Thanks
Hi @KOUAMI,
You can use the Plots tool in HyperView and choose to plot Stress by Elements.
Then you can export the plot as a CSV using File » Export » Curves » CSV Blocks.
Hope this helps!
Adam Reid
Hello, thank you for your reply it is very helpful. But i have a second question:
is it possible to write a macro to automated post-processing?
Best regards
Yes, this should be entirely possible with the help of Tcl or Python commands.
I would check out the Altair Exchange page to see if any scripts have already been uploaded with a similar purpose, or to take pieces from each script to accomplish your goal.
Another option would be to save the Session as a Flexible Report, to which you can use it as a template to automate the setup as well.
