Hi everyone,
I’m having an issue when running a static ride analysis in MotionView. The first run usually works fine, but when I try to run the same analysis a second time, it always throws errors — even though I haven’t changed any parameters in my imported model.
Has anyone encountered this before or knows what might be causing it?
Thanks in advance for your help!
