Connecting HyperStudy with HyperSpice & LTspice using a PSIM schematic
PSIM gives three different solver options with PSIM (default), Altair's HyperSpice, and then a link to LTspice. You can use our design of experiments and automation tool, HyperStudy, to run automated simulations with any of these solvers.
That being said, there is a bit of setup required to run HyperSpice and LTspice this video explains how. Please keep in mind that the video focuses on HyperSpice but you are able to use LTspice solver too.
At 0:50 in the video, the Compose script connects PSIM to the Hyperspice solver using the PsimSimulate_HyperSpice() function. To connect PSIM to the LTspice solver instead, you can only use the PsimSimulate_LTspice() function.
Relevant Links
Run LTspice from PSIM and Define a Dual PSIM/SPICE Model
How to Automate LTspice Using Hyperstudy
