Hi everyone, thanks for your patience!
I have performed measurements along the rotor axis (z-direction), where the sensor moved parallel to the rotor while maintaining a constant distance from its surface. I would now like to reproduce these measurements in a simulation. How can I evaluate the magnetic flux density at a defined distance from the rotor surface along the z-axis? Ideally, I would like to define a line parallel to the rotor with multiple sampling points along that axis.
Maybe someone has a beginner friendly solution and description - thanks!
Best regards.
