The Sample Dataset
We’ll use a tiny dataset of 5 movies, small enough to test in AGS but just enough to illustrate SPARQL features.
Movie ID | Title | Year | Rating | Genre | Director | Actor |
M1 | The Shawshank Redemption | 1994 | 9.3 | Drama | Frank Darabont | Tim Robbins |
M2 | The Godfather | 1972 | 9.2 | Crime | Francis Ford Coppola | Marlon Brando |
M3 | Inception | 2010 | 8.8 | Sci-Fi | Christopher Nolan | Leonardo DiCaprio |
M4 | The Dark Knight | 2008 | 9.0 | Action | Christopher Nolan | Christian Bale |
M5 | Pulp Fiction | 1994 | 8.9 | Crime | Quentin Tarantino | John Travolta |
About This Dataset
This Movies dataset is a lightweight, illustrative sample designed for all SPARQL KB articles in this series.
It contains just 5 movies -enough to demonstrate graph joins, relationships, and filters - while keeping query performance instantaneous in AGS.
Purpose:
- To give developers a common base dataset to test and validate queries.
- To ensure examples remain consistent across KBs (no need to reload different data each time).
- To help visualize real-world relationships — e.g., movies sharing the same director, or actors appearing in multiple genres.
Structure Overview:
- Each movie (
ex:M1–ex:M5) is a node of type ex:Movie. - Each has properties like
ex:title, ex:released, ex:rating, and ex:genre. - Relationships connect movies to
ex:director and ex:hasActor. - Each director and actor is a
foaf:Person with a foaf:name.
Example triple pattern:
ex:M1 ex:director ex:Frank_Darabont
ex:Frank_Darabont foaf:name "Frank Darabont"
The AGS Perspective: From Tables to Triples
Unlike a relational database that uses tables, rows, and columns, AGS (Anzo Graph Server) organizes all data as triples:
Subject → Predicate → Object
Each triple is one fact — for example:
ex:M1 ex:title "The Shawshank Redemption"
ex:M1 ex:genre "Drama"
Unlike SQL joins, AGS traverses relationships natively using graph patterns.
This allows you to discover linked entities like movies by the same director or actors appearing in multiple genres.
📘 Learn more: SPARQL Basics
How AGS Uses SPARQL
- AGS is an in-memory, massively parallel graph database.
- SPARQL queries execute across distributed nodes for speed.
- You can connect directly through the Query Console or GDI service.
- AGS extends standard SPARQL 1.1 with:
- Parallel execution for scalability
- GDI + SERVICE clause for data virtualization
- Named Queries, incremental loading, and Query Console features
Core SPARQL Query Types (with Movie Examples)
SELECT - Retrieve data
PREFIX ex: <http://example.org/movie/>
SELECT ?title ?rating
WHERE {
?m a ex:Movie ;
ex:title ?title ;
ex:rating ?rating .
LIMIT 5
Output (example):
"The Shawshank Redemption" | 9.3
"The Godfather" | 9.2
"The Dark Knight" | 9.0
"Inception" | 8.8
"Pulp Fiction" | 8.9
Executed in-memory for sub-second retrieval. Use LIMIT while testing.
📖 Learn More: SPARQL Queries
CONSTRUCT - Create a new graph
Create triples linking each movie to its director’s name:
PREFIX foaf: <http://xmlns.com/foaf/0.1/>
CONSTRUCT {
?movie ex:hasDirectorName ?name .
WHERE {
?movie a ex:Movie ;
ex:director ?d .
?d foaf:name ?name .
LIMIT 3
Output:
ex:M1 ex:hasDirectorName "Frank Darabont"
ex:M2 ex:hasDirectorName "Francis Ford Coppola"
ex:M3 ex:hasDirectorName "Christopher Nolan"
Useful for reshaping or exporting graph structures.
INSERT DATA - Add triples
PREFIX xsd: <http://www.w3.org/2001/XMLSchema#>
INSERT DATA {
ex:movie/fight_club a ex:Movie ;
ex:title "Fight Club" ;
ex:released "1999"^^xsd:gYear ;
ex:rating "8.8"^^xsd:decimal .
For small loads. Use GDI pipelines for large datasets.
DELETE DATA — Remove triples
DELETE DATA {
ex:movie/fight_club ex:rating "8.8"^^xsd:decimal .
Removes specific triples from the graph.
ASK - Boolean existence check
ASK {
?m a ex:Movie ;
ex:rating ?r .
FILTER(xsd:decimal(?r) > 9.0)
Output: true
SPARQL in AGS vs SQL
Concept | SQL (Tables) | SPARQL in AGS (Graphs) |
Data Model | Rows & columns | Triples: subject–predicate–object |
Query Target | Fixed schema | Dynamic graph patterns |
Relationships | Foreign keys / joins | Direct graph edges |
Execution | Disk-based, sequential | In-memory, parallel |
Federation | ETL into warehouse | GDI + SERVICE = live queries |
Developer Quick Wins in AGS
- Always test with
LIMIT. - Use typed literals for filtering and sorting.
- Prefer
VALUES over complex FILTER logic (for performance). - For big joins, use subqueries or WITH clauses (for modular performance).
📖 Tooling: Query Console
📖 Data Loading: Manage Data
Where to Learn More
