Monarch Pro 15 stopped connecting to SQL server via ODBC connector
Altair Forum User
Altair Forum User
edited September 2018 in Community Q&A
Ran process where data is pulled from connection via ODBC to SQL server.
Ran 4 weeks ago with no issues.
Password has not been changed in this time, and still works when connection is tested - see screenshot
Has something changed in regard to what I can undertake (i.e. license controlled?)
Please can I have an urgent response, this is impacting critical processes.
Get this message-  see screenshot
Enter password when prompted - see screenshot
ODBC connection is OK - see screenshot
  • Altair Forum User
    Altair Forum User
    Hi Vanessa,
    For the most timely response, I recommend contacting support via https://www.datawatch.com/support/ or support@datawatch.com
    The middle screenshot is suggesting a mismatch between 32 and 64 bit architectures.
    Assuming default locations are used, if Monarch in in the 'Program files' folder, it will be 64 bit.  If it is 'Program Files (x86)' it will be 32 bit.  The driver in use is 64 bit (according to the lower screen shot), and must match the bit level of Monarch
    This could have changed over the last 4 weeks for many reasons, including
    A reinstall of Monarch at a different bit level
    A reinstall of the Postgress driver at a different bit level
    A new or reinstall of any application that may have also (silently) changed the bit level of the driver
    Steve.
Welcome!
Welcome!
