Hello, I can't figure out why my HyperLife model is showing a damage above 1 (and therefore <1 cycle of lifetime). I am importing a nastran file, the stress in HyperLife shows 1.06e4, while the NX result is 106 MPa. I thought this could be the problem, but scaling the force by 1/1000 results in no stress at all. Does anyone have other ideas of what might be happening? I tried using multiple library materials, most likely ruling out a problem with the SN curve input data.
