In general practice, when you want to export and import a fully developed suspension system into either a complete vehicle model or another build with the same architecture, the recommended approach is as follows:
- Export the system via:
- File > Export > MDL Definition
- Select the system
- Choose the directory to export the model
- Click Export
- Import the system into the target model:
- First, delete the preexisting suspension system from the model.
- Then, import the previously exported system file.
Common Questions About This Workflow
- Can I import a suspension system from a different library (e.g., Heavy Vehicle, Truck, Small Car, Two-Wheeler, or a custom library) into a model that doesn’t originate from the same library?
- Can I repurpose a front suspension system to be used as a rear suspension system (or vice versa)?
- In multi-axle vehicles, can I reuse the same rear suspension multiple times within the same model?
The answer to all these questions is: Yes, it’s possible! However, there are some important considerations.
Attachment Compatibility:
System attachments might not have the same attachment tags across different libraries. This can lead to unresolved system attachments upon import.
Front-to-Rear or Multi-Use Reassignment:
If you’re converting a front suspension for rear use, or reusing a suspension multiple times in a multi-axle model, attachments may still resolve to the original system. This has arisen when dealing with driveline, spring damper, and brake systems.
For instance, if a driveline system is connected to a duplicated rear suspension, it may automatically attach to the first rear axle by default.
How to Resolve These Issues
In this example, I will be using a front rocker suspension system and importing it for use as a rear suspension. There are two methods you can use to ensure the system integrates correctly:
- Manually Update the System Post Import:
- After importing the system, manually update the system attachments in the model to ensure correct connections.
- Modify the .mdl File Before Import:
- Update the varname of the entire system.
- Change the attachment tags as needed.
- If done correctly, this ensures that attachments are resolved automatically during import, eliminating the need for manual intervention.
For both scenarios, you may need to update the hardpoints of the model, this can be easily done with Data Summary!
I hope this helps you along your modeling journey!
Additional Resources
