I am trying to apply a rotational displacement to a disc. I have fixed the small holes with dof1-3. I have also fixed the centre node with dof 1-6. On the centre node I have also applied an SPCD in dof6 of 10 radians. I have connected the centre node with the inner hole at few points using RBE2. I am running nonlinear quasi static analysis. When I view the results in Hyperview the centre hole seems to split up (see picture). could you please advise what can I do get correct behaviour.
Thanks
Ahmed
Results View
