the scketchs faces in the image plane have no origine counterpart.
The geometry is not periodic.
I don't understand this error, the faces are not existing faces, I use these faces to have circolar extrusion. The geometry is periodic
Hello
Can you please add more detail to your question?
What product is this for?
Can you show an image of the issue?
To fix the problem you have to drawing the geometri using sketches that are in the periodicity space but not on the periodicity plane. This is the correct workaround for this Flux bug
