Personal altair slc with matlab sympy and r finite element cold plate heat transfer
Too log to post here, see github
see github
https://tinyurl.com/3f9w97t2
https://github.com/rogerjdeangelis/utl-personal-altair-slc-with-matlab-sympy-and-r-finite-element-cold-plate-heat-transfer
OUT OF MY COMFORT ZONE<, BUT PERHAPS SOME OS THIS MAY BE USEFUL?
Examples of solving a cold plate heat transfer problem using
Finite Element Analysis (FEA) in R. This example models a simple rectangular plate
with a cold boundary condition on one edge and a heat source in the center.
CONTENTS (very simplistic examples - out of my comfort zone on mach of this)
1 slc python matlab (via open source Octave)
This is how you execute matlab code inside the altair slc.
oc.eval("objfun = @(x) (x(1)-3)^2 + (x(2)-5)^2;")
2 slc smypy SLC, Exact solution to the one dimensional heat transfer problem,
I do realize very few heat transfer problems have closed form solution
but intial estimatation using a closed form can be useful?
3 slc r interative solution
graphics
https://tinyurl.com/ms3thwep
unfortunately Altair SLC dos not support ascii contour plots
heatmap https://tinyurl.com/5n97pucx
options ls=64 ps=32;
proc plot data=wantxpox ;
plot y*x=z / contour=5 box;
ERROR: Option "contour" is not known for the PLOT statement
In the spirit of John Tukey, manual editable ascii graphis provides insights to data.
Maybe Seimens will bring ascii grahics up to the sas level.
Also parmcards4 is critical for integration, maybe add parmcards to the personal SLC.
4 slc r finite element solution cold plate
Graphics
https://tinyurl.com/yeyjwtk6
https://tinyurl.com/ywxmp4yb
https://tinyurl.com/3n6zsy8f
5 Repository categories (although many of the categories involve sas, it should be easy to convert to the SLC)
SYPY
AI
MATLAB
POWERSHELL
SPSS
POSTGREQL
MYSQL
SQLITE
EXCEL
3 iterative solution
https://github.com/rogerjdeangelis/utl-solving-one-and-two-dimensional-cold-plate-heat-equations-r-and-python/blob/main/heatequ.png
github
https://tinyurl.com/2dxceary
https://github.com/rogerjdeangelis/utl-personal-altair-slc-with-matlab-sympy-and-r-finite-element-cold-plate-heat-transfer/blob/main/fea1.png
https://github.com/rogerjdeangelis/utl-personal-altair-slc-with-matlab-sympy-and-r-finite-element-cold-plate-heat-transfer/blob/main/fea2.png
https://github.com/rogerjdeangelis/utl-personal-altair-slc-with-matlab-sympy-and-r-finite-element-cold-plate-heat-transfer/blob/main/fea3.png
