1] I want to check the mutual coupling between two SPH sources separated by distance of 900mm. For that i have two SPH sources oriented in Broadside direction of Patch antenna array & 45 degree in XY plane.(Note : Both the sources are oriented in Azimuth plane). if we can check the mutual coupling between these equivalent sources in feko, kindly give the workflow to carry out such type of analysis.
2] While working with those sources individually, there radiation patterns was as shown in the attachments.
Fig: Broadside Rad. Pattern
Fig: 45 Degree Rad pattern.
when these aources we combined in one file ideally they should retain their Rad. patterns . but, it was seen that both the rad.patterns changed, as shown in fig.
i suspect these equivalent sources are interacting with each other because of that their rad.patterns are getting changed .
