I want to check the power handling capability of my conformal array antenna; for that, I created the near-field surface from the top of the patches to the cylindrical
 ground plane. I want to check the electric field value at the top of the patch surface, the dielectric layer, and the ground plane, because these three regions have different breakdown voltages.  In FEKO, the 3D bar plot of E-field value is not trustworthy it shows different values each time for the array. How can I see the Electric field value in FEKO for these three layers of the array antenna? [The array antenna is attached here.] Kindly help me out.
