I experimented with the converting 2*2D antenna pattern to 3D antenna pattern in Aman, however, I found that the 2D antenna pattern only contains angle and magnitude information, without phase. Does the result of 3D antenna pattern have phase? Can Aman convert the phase of the antenna pattern, or do all the antenna pattern converted by this method lack phase?
If I use this phase-less antenna pattern as the source to simulat in Winprop, will the simulation results of two projects that are exactly the same except for receiving power set to coherent superposition and incoherent superposition differ?
