Hi, I'm very new to altair external functions, so I'm strugeling to get an output as a 3x1 matrix. If anyone can give a kind support would be greatly appriciated.
Can you please specify which product/software you are referring to?
Hi, I'm using Altair Embed x64 Pro 2025.
In Embed you can specify the C function and access it using Extern feature. Attached one example.
Included one example for matrix input. In Embed you can do the matrix arithmetic and return the final output.
You can also include the library file into Embed also and use it.
Please go through the attached document and let me know.
Sreejith
