A few months ago, I asked three questions about the Panopticon dashboard.
I tried again after updating to 2025.0.1 and the recently updated 2025.1.1,
but issues 1 and 2 still persist.
1)
When I add an action slider and an action text box to the dashboard,
there is no problem with the result output when entering numbers directly into the text box.
However, when using the slider, the output items intermittently disappear.
At the same time, the value in the action text box changes as the slider moves, and this value displays a lot of decimal points.
I don't know if this is the cause, but it also seems unfavorable from a user experience perspective.
2)
When I create an action that inputs multiple input sets, such as an action form or action button, and then click it, I can see the input variables change in the action text box on the same dashboard.
However, at this point, all the output label screens suddenly disappear.
There seems to be a problem with the result output when entering multiple inputs.
I have confirmed that issue 3 has been fixed.
Thank you.
