Hello everyone ,
I am meshing a cooling plate . the cooling plate basically have two plates : a) channel plate b) base plate .
Both the plates are brazed together
I have meshed base and channel plate separately .
How should i join both the plates to get real world scenario.
I have attached an image with top plate as channel plate and one base plate at bottom.
Both the plates are joined together in all region except where the channels(fluent flow path ) are there
