Hello Altair Community,
I'm hoping for some help with a launch issue for the Student Edition of FluxMotor 2025.1.
When I run FluxMotor, the splash screen appears and stays there. The process is running in the Task Manager with very low CPU/Memory usage, but the main application window never opens. I have to use the Task Manager to close it.
- Altair Flux works perfectly. I can open it and use it without any issues, so I believe my student license is working correctly.
 - A friend with a similar laptop has the exact same problem.
I have already tried some solutions like running as an administrator, forced the program to use my high-performance NVIDIA GPU via the NVIDIA Control Panel,  and doing a clean reinstall, but the problem remains the same.
Has anyone else experienced this or have any suggestions?
System Specs:
- OS: Windows 11
 - GPU: NVIDIA GeForce RTX 3050 Ti Laptop GPU
Thank you for your help!
