Hello everyone,
I’m currently working on a thermo-elasto-plastic analysis and have run into two questions regarding the creation and configuration of the TABLEST card. I would really appreciate it if colleagues with relevant experience could help clarify these doubts.
Question 1: Do I need to add a TEMPD=25 card for the room-temperature fastening case?
When accounting for thermo-elasto-plasticity, I need to create a TABLEST card. My analysis involves two main loading cases:
- The first case is fastening at room temperature (25°C);
- The second case is high-temperature analysis after the fastening process.
To ensure that the analysis can correctly reference the 25°C TABLES1 curve in the TABLEST card during the first case, do I need to include a TEMPD=25 card in the room-temperature fastening case?
Question 2: Why is a temperature-dependent yield strength curve not required for defining ?
I noticed that when setting up the thermo-elasto-plastic analysis, we typically need to reference a temperature-dependent elastic modulus curve in MATT1. However, it seems unnecessary to include a temperature-dependent yield strength curve. Could someone explain the reason behind this?
Thank you in advance for your help and insights!
