Dear community,
I would like to create a new radar model in WRAP (v 2025). The radar is equipped with an Active Electronically Scanned Array (AESA) with given Field of Regard (FOR) in azimuth and elevation.
From the Altair WRAP 2025.0 User Guide Chapter 11.1 I found: "It is possible to define if the radar shall be directed to the calculation point or if the antenna direction
shall be fixed. The antenna may alternatively be set to scan mode in the horizontal and vertical plane."
So I am asking your help on the following:
-  What is the easiest way to create a new radar system, equipped with an AESA?
 - How can I model the scanning operation? I am not interested in the surveillance time but just the antenna beam will point in all the angles of the FOR.
 - Is there any tutorial showing how to create a new radar system? I have already considered the project Radar.wpr (WRAP Example Guide - Chapter 11)
Thanks in advance for your help and attention,
Regards
Luca
