I want to create a super unit for multi-body dynamics students, with a concentrated force of 1000N in the middle of the super unit and two end holes as hinge points with multi-body dynamics. I am a bit confused now. Under the CMSMETH card, should I choose Preload or LoadSET? If Preload is chosen, will SPCID be based on ASET geometry, or will two additional SPCs be created in RBE2? I feel like I can't quite understand the help document CMSMETH. Another question is whether the generated super unit in Motionview is subjected to a gravity field, or does it need to be added with a gravity field during the generation of the super unit?
