Description: Hi, I have two questions I would like to ask you guys about HyperForm!
- Saving the results: I am following the tutorials and have run some simulations, but the result files are saved in .rst, .out, and .rad. I cannot seem to be able to open these files to take a look at the result. Is there a way to fix this?
- HyperForm Tutorials: I am currently in the process of learning how to use HyperForm. Do you guys have any suggestions on what kind of tutorials I can refer to for HyperForm, specifically hot stamping?
Thank you so much in advance!
