I would like to write a script which retrieves the material set in the model tree for each body in the Model. Is there a way to do it?
e.g. I would like to write a script which returns Material as 'Polymer_2' for the selected body
Hello Aashish,
There's no function available for this yet. You can use this script to obtain xml file with the desired properties.
Kind regards,
Marc
Okay that should work as well. Thank you for your response.
