Hello there,
How can I select the features (design or performance) which I can use to compare the motors in the Comparator? I need to compare more/other things than are the default in the Fluxmotor Motor Comparator
Hi Faisal,
Thank you for contacting forum.
To compare the design or performance of the motors simulated in FluxMotor, we need to perform Datasheet test(and save the motor) in the Test ribbon.
Thanks
Karun
Hello Karun,
Thanks for responding.
My question is more like what if I want to add torque ripple, peak airgap magnetic flux density to the Comparator table. I do not see those parameters in the default comparison table generated by the Comparator. I would like to know how to add these parameters to the Comparator table
Full disclosure: I am trying to compare 2 induction motors.
BR, Faisal
Unfortunately, there is no provision to add the quantities to the list, since the list is based on the quantities we obtain from data sheet test.
Hi Karun,
Thanks for the reply. Perhaps this flexibility is something that Altair might look to add in the future versions.
Thanks for replying. Best, Faisal
