I reported on a similar issue last year.
The visualization portion of the result view was not displayed, even when HTML5 Safe Mode was checked.
Since then, I've discovered that when running AI Studio, multiple Chromium processes are running, two of which are running in Incognito mode. The image below shows the process information for one of the two.
I noticed this issue because I heard from the customer's IT department that their internal security program automatically blocks Incognito mode.
Since this issue occurred only at this customer, I thought this could be the primary cause.
Could this be the issue?
Also, is there a way to change the Incognito mode to normal mode?
I would appreciate your help.
