Hello everyone, I would like to inquire whether overlapping is used instead of particle deformation in Edem software. Why did I set a high plasticity ratio when compressing particles using the EEPA model, and the rebound of the particles was still significant even after releasing the pressure. And many particles will separate after significant overlap and release of pressure, which is equivalent to no plastic deformation.And I also found that when a large constant pulling force is applied, the particle blocks will shrink significantly, sticking together and overlapping greatly I hope to receive everyone's answers, thank you.
