I am currently learning how to couple Motionview and Optistruct in Hyperstudy. I want to use the thickness of the flexible body generated by Optistruct as a variable and the stress of the flexible body as a response. Of course, the thicker the thickness, the smaller the stress may be. I just want to learn how to perform the operations I want to do in Hyperstudy for the convenience of future work.
The model is like this:
I encountered a problem building my model in Hyperstudy. When I was optimizing, Motionview did not recognize the flexible body I wanted. The model associations in Hyperstudy are as follows:
This is the result value of Hyperstudy optimization, which has not changed. It should be that the flexible body model is not related. How should I handle it? Is there any relevant reference material available
Compress files for my model and settings
