I'm trying to apply a single pressure load to the face of an orphan mesh.
When I try to create a pressure load applied to a surface, I am unable to as elements are the default entity type and the box is greyed out:
When I select an entity face set, as it's the only option I have, it creates a load for every entity in the set. This ends up being thousands of individually applied loads instead of one pressure load applied to a surface:
Help is much appreciated,
Thank you
Software version:
