Hi. I have set up a structural analysis model of a beam with with sliding contacts at each end connecting to pins that are supported/fixed, a force is applied to the centre of the beam. Despite the model being completely symmetrical with the same contacts on each side,
the results show that each pin has a different amount of stress (around 10% different between each side).
Can anyone advise why this is and how I can fix or improve it?
Thanks
