I’m currently working with the Fiber Bonding model and had a few questions regarding the stiffness calculation described in the documentation.
Let’s consider a case where sphero-cylindrical particles are like below.
Let’s consider a case where this sphero-cylindrical particles are aligned in a straight line and arranged so that they overlap exactly by their radius, as illustrated in the attached image. In this case i have some questions.
- Cross-sectional area:
According to the documentation ( figure below ) , stiffness depends on the cross-sectional area of the bonded region. In the configuration above, is it correct to assume that the cross-sectional area refers to the orange line segment area in the image, and therefore its value would be π·r², where r is the radius of the sphero-cylinder?
I would appreciate clarification on how this area is defined in your model.
2. d₁ and d₂ values (distances from the particle centers to the contact point):
In the stiffness formula, how is the contact point defined in this type of overlapping configuration? Knowing this would help determine d₁ and d₂ more precisely.
3. Beam Interpretation in Multi-Contact Particles:
The documentation states:
“The bond emulates the flexibility of the adjacent particles, from their center to the contact point, originating from the theory of beams.”
Given this, can we interpret that in the case of a meta-particle connected to two neighboring particles (left and right), each sphero-cylinder effectively forms two beam elements, one to each adjacent particle?
In other words, would it be physically reasonable to assume that the configuration shown in the attached bottom image, with a particle flexing between two neighbors, is supported by the Fiber Bonding model?
4.
Lastly, is there a detailed tutorial that walks through the entire process of building a simulation using the Fiber Bonding model?
Thank you very much for your time and support. I look forward to your clarification on these points.
